This morning I initiated work on wing # 2. Hopefully this should take less time that the first wing since many of the parts have already been fabricated. Unfortunately as soon as I started I realized I dod not have enough L angles to finish re-enforcing the wing rear ribs, so ... I had to fabricate more L angles. With the help of my wife's causin Thomas, we took the "dead" hydraulic riveter apart. We found that the rear cap seal had worn. Since this seal is about 4 mm thick, we decided to reverse it. After cleaning and lubricating all the components, we put the riveter back together. It worked... just like new !! Thank you Thomas !
