Installed the Elevetor stops. I installed the lower stops per the advisory from Zenith dated 3/08 that calls fot the maximum deflection between 12 - 15 degrees downward. I was not happy with the design by Zenith that uses the fiberglass saddle as the upper stop, so I designed a simple stop that uses the upper horn against a nylon 66 surface.
