Brief Description: 1.- Installing the L angle under first tube frame
This is a little item that can be easily missed on the drawings. That is the L angle that connects the rear upright channel with the first tube frame. I decided to fabricate a wider/stronger "L" angle out of .032 material. I also installed it facing forward since it provides a larger contact surface so as to install 2 rivets.
