N115AR 601XL - FOR SALE
Zodiac 601 XL
Fixing boboo
Drilled the new L angles (0.040) and cut the 2" hole on the new top stiffener. Now I was able to center the hole 60 mm from the firewall per the specs.
Installing L angles to replace cut flanges
Cutting hole for upper bearing
Test fit... EXCELLENT
601 XL Upgrade Home
Zodiac 601 XL Home
1278
420
Instruments/Avionics
43
Research
455
