Brief Description: Drilled the bottom longeron to side skins
As you can see, I had to figure out a way to drill the lower longeron. you would think this would be easy but given my space restrictions and the fact that the 10' bend brake is actually mounted on the work table,, that meant I would have to eitther move the hole table or dismantle the bend brake. Well... I bought two 10' 3"x3" square tubing (only $16 a piece) and sat the fuselage on them. This killed two birds with one stone... one the drilling of the lower longeron and two, the leveling of the work surface (table has a slight warp/wave going on).
