Brief Description: 1.- Second test trial on solid riveting
Based on my first trial, it became very evident that I needed to make sure that I rigged rup the table so that the spar would lay perfectly level to the table and at the right height so as to set the rivet on the C frame riveter. Once I rigged the table with a couple of levels plus a 3/4" particle board would give me the perfect setup, I started riveting. I riveted 7 solid rivets and I was happy with the results.
