Brief Description: Cutting Aluminum for Spar Cap Angles
Well ... remember I decided to build the fuselage first... well not so fast. I will need to build the center wing spar and the wing spars so that I can drill the 12 holes that will hold the wing bolts thereby setting the wing dihedral angle. After completing this I will be able to start building the fuselage. So I started by bringing down the 12' long sheet of 0.032. I cut four pieces for the Spar cap angles that were about 50 mm wide (giving me extra material so that the bend brake is able to hold and bend without any surprises). Afte this, I would cut the pieces required for the center spar webs.
