N115AR 601XL - FOR SALE
Date:  3-5-2007
Manual Reference:  6T1-7HD
Brief Description:  2nd attempt at Stabilizer Spar doublers
After a bad weekend (lots of hours spent with zero production), I decided to email my good friend Dave Clay. THANK YOU DAVE ! He suggested I try bending at least 100mm wide piece and then cut to specs. What a difference! The problem was that the bend brake was having a tough time holding the 0.040" material in place. In fact, the material shifted back about 7 mm before it actually started bending. To reach the 96 degrees called for by the plans I attached a piece of square tubing and kept bending.
Used square tubing to finish the bend
Notice how the material moved
Compare first attemp. Vast improvement!
