N905AD Web site
Date:  5-27-2007
Number of Hours:  10.00
Manual Reference:  12/6
Brief Description:  Completed Spinner
Removed spinner and cleaned up excess fiberglass around front plate buildup. Safety wired prop bolts. Replaced spinner with clecoes and checked fit. OK. Completed second prop filler plate and primed parts ready for completion. Drilled out all mounting holes for spinner and removed spinner. Then riveted in nut plates for attaching spinner. Also riveted filler plate parts together and added platenuts. Then assembled spinner using the round head screws provided and riveted in the prop plate filler plates behind both blades and also screwed these into the spinner with round head screws.
Completed Spinner
Completed Spinner
