Worked on installing platenuts on wing roots. Drilled out all holes, deburred and riveted platenuts in position. Dimpled wing root skins and tested installation. Installed platenuts on wing forward attach brackets. Also cut notch in fuselage forward attach brackets and drilled hole for safety wire. Secured all wing mounting hardware. Wings done!
