Ordered radio, transponder and intercom. Order includes tested wiring harness for these components. Order to be completed in about 3 weeks. Reviewed install manual for autopilot and determined will need another override On/Off switch for the autopilot. Plan to add this between the exisitng switches and circuit breakers. Working on a mockup of the lexan to be used to insure proper placement of the switch. Also reviewed placement and mounting of the autopilot servo mechanism (in the belly on the pilot's side).Uncrated the Quickbuild wings and set them up for easy work on both wings. Wow, a lot of work has already been accomplished on the wings! First thing up is to complete the mounting of the fuel tanks (overlooked by some Quickbuilders).
