Cut and fit both Horizontal Stabalizer tips to match elevators. Drilled attachment holes and mounted using clecos. Checked for fit. Cut backing support for each tip, then fiberglassed open ends of tips. Cut and fit the Vertical Stabalizer tip to match rudder. Drilled attachment holes and mounted using clecos. Checked for fit. Cut backing support for the tip, then figerglassed open end of tip.Cut fit and mounted Rudder upper fiberglass tip. Drilled attachment holes, and riveted tip to rudder. Cut and fit Rudder lower fiberglass tip. Awaiting fitting of tail light before mounting.
