Worked on Cabin Steps. Cut holes for steps with hole cutter. Enlarged as required to get steps to fit properly in holes. Added reinforcements to steps to prevent cracking. Cut holes in bearing blocks and drilled rivet attach holes. Also drilled bolt holes for attaching bearing blocks. Removed steps for powder coating.
