Drilled F-6116 bearing block bolt holes. Drilled multiple locations for bearing block attachments. Trimmed F-6118 Pedal Brace, clamped to firewall brace and drilled and deburred. Cut, fit, and drilled the center bearing block to the rudder peal tubes. Attached brake fluid reservoir to firewall.
