Completed fabrication of attach angles and match drilled to main spar assembly. Completed rear spar assembly with outboard hinge brackets. Match drilled all holes to #30.NOTE: Still need to widen the manual trim hole in the main spar. Partner Daryl Sahnow on the left and myself (Andy Rux) on the right.
