Dimpled aft top skin. Positioned and riveted center portion of skins. Then began work on baggage floor before closed sides of aft skin. Took pix of underneath floor area if need for refernece. Fitted floors and side panels and riveted in place. We replaced the lower rib blind rivets with platenuts in case we ever need to remove the bottom panels. Thus the screw heads you see in the photo.
