N905AD Web site
Date:  6-3-2007
Number of Hours:  8.00
Manual Reference:  N/A
Brief Description:  Electrical Open Items
Mounted magnetometer and connected to EFIS wiring harness. Worked on mounting GPS. Aftermarket case needed 'tweaking' to get AVMAP to slide in and out. Still works a little hard, but securely mounts GPS. Tested GPS with aircraft power: OK. Need to get outside to get a fix - no signal inside shop. Fired up comm and intercom and tested both. Work OK. Pilot's and co-pilots mic buttons both work OK. Tested autopilot. Setup and tested servo movements: OK. Wired EFIS audio output into comm/intercom system. Now fully ready to connect to EFIS/EMS when it arrives.
Magnetometer mounted
