Routed wires for flap position sensor. Identified and marked all engine sensor wires. Now have all wires routed in cabin. Wire tied cable assemblies running through center console, ready for cover to be attached. Installed cabin heat cable, routed cable, cut to length and attached to cabin heat vent. Tested operation and have full open and full close. Attached center console cover. Reconnected manual trim cable and tested operation. Attached fuel valve cover and side covers. Installed carb heat cable, routed cable, and installed firewall grommet for carb heat cable. Installed throttle cable, routed cable, and installed firewall grommets. Also installed mixture cable, routed cable, and installed firewall grommets. Attached cable plate to center console. Reinstalled tip-up holddown rod and tested operation; OK.
