N905AD Web site
Date:  7-23-2006
Number of Hours:  10.00
Brief Description:  Wing Lighting
Cut right wing tip using RV10 landing light kit. Determined this will fit into RV9, so will use it for both wings. Completed build up of landing light assembly for right wing; need to complete attachment.Routed wiring for left side wing tip landing light through left wing and through fuselage to landing light switch. Completed making connections to nav lights and landing lights in both wings. Completed connections for strobe light wiring break at wing root on both wings.Mounted autopilot master switch with new lexan backing and wired into guages breaker. Added a 10 amp fuse in-line with DC power plug to prevent excessive current draw from battery.
Wing Tip Wiring
Wing Tip Wiring
