Drilled cabin frame brace rivet holes. Finalized frame support positions and drilled forward screw holes using skin holes for alignment. Then drilled rear screw holes and inside bolt holes. Countersunk rear screw holes. Then tapped forward screw holes; drilled out skins for these screws; dimpled skins; and finally countersunk holes. Inserted bolts and screws temporarily for positioning.
