Brief Description: Right Tank Ribs Sealed and Riveted
Bill Pinney came over today and helped me rivet and seal the remaining four inboard ribs in place. We got in a good system and timing and didn't take too long. I had enough sealer left after the last rib that I went ahead and sealed/ riveted the most inboard rib in place. Tomorrow I should be able to get the capacitance fuel level plates and wiring and the vent line all setup as well as the reinforcements for the nose on the inboard rib and the fuel flop tube sealed in place. Then maybe the most outboard rib and perhaps (if I have enough sealer) I can get the baffle sealed in place on Monday and leave the right tank to cure for the week I am gone to work. We shall see.
