Photo #1 shows the elevator horn held in position. The kit plans call for making a drill bushing to go thru the hinge bearing and then drilling the hole. Since I didn't have any scrap metal tubing laying around, I just marked the hole with the bolt and then drilled it out after the elevator was removed from the HS. Photo #2 shows the hole after drilling. I then remembered that I needed to enlarge the cutout in the flange of the HS rear spar to allow room for the left elevator control horn to swing thru. Photo #3 shows the initial cut complete before I smoothed it out. See next entry for the rest of the days work.
Ready to mark hole in Right Elevator control horn
Hole drilled in the Right Elevator control horn
Enlarging the cutout in the HS rear spar flange to allow freedom of movement for the elev control horn
