Today I fitted the fuel tank and drilled the leading edge for the front ribs. The method uses drafting tracing paper and marking the place to drill when the leading is at not pulled down and then pulling the leading edge back into place and then put the tracing paper back in place and bingo you have the drill spots marked (thanks to someone on the Zodiac Matronics List)
