I am getting back to building. Tonight I did the fix that Zenith sent me to fit the rear spar, I drilled the Aileron crank rod hole in the wrong spot, at the top of the spar and not the bottom, as I should have. Fitted the repair doubler and riveted the rear spar onto the wing. Levelled the wing and set it up for the top skin to be put on.
