Brief Description: drill holes to final size for A5 rivets
Drill holes to final size for A5 rivets. Remove L angles and doublers deburred. Drilled aileron doubler plate 1.5 inch hole and clecoed doublers and L angles to spar. Remove the Aileron Bellcrank and drill out the rivets attaching the Aileron Bellcrank Supports and Bellcrank. Drilled new support channel using old for template deburred and attached support Channel to the Rear rib with clecoes.
