Brief Description: mounted wire brackets to hold support wiring
rivet brackets in rib holes to hold all wiring drilled ribs for rubber groments. Install rough in wiring with weather packed connectors through rubber grouments installed in brackets and ribs. Wiring for wing light strobe. wing light, stall warning, airlaron trim, pitot heat and sense hose line.
