Alans Web Site
Date:  5-23-2022
Number of Hours:  4.00
Brief Description:  instrument and counsol panels
I made a bracket to hold my collision avodiance display to mount under instrument panel. When I re designed the instrument panel I had no room on the panel to install it. I made larger L gussets for the counsol bottom sides and new l gussets for the upper that supports the instrument panel. I Started wiring the instruments and gauges. I made a grounding point on instrument panel from a grounding board I purchased at Air Craft Spruce.
counsol
counsol
clecos size of rivets
ground strap
ground strap
