Installed 8 new cylinder head studs in place of old rusted ones. Crankshaft purchased for clark's new cylinders, pistons rods rings, valves, valve guides springs seals, gasket set. Assembled and torqued engine block together with machined and nitrated crankshaft and new IT 10 camshaft and gears. .Mounted engine on stand. Installed machine cylinders and new forged pistons .020 over bored from Clarks torqued rod bearings Used Arp rod bolts with new 12 point nuts for ease of torqueing, use my new snapon torque wrench. Installed front engine cover with new crank seal and harmonic balancer. Still waiting for intake manifold I ordered from WW. (16 months ago) Cylinder heads overhauled with new valve guides and valve seat lapped to new valves. Heads not assembled with valves yet I am waiting for intake maniflod before I assembly cylinder heads, because of modification I need to make on intake of heads to match WW intake Manifold.
