Alans Web Site
Zenith CH601 XLB
6-W-0
drilled bottom wing panel
marked rivet lines on wing spars, flipped right wing assembly over. Cut 2 by 4 blocks to level and hold wing assemlby level . Shime spars to level. Layed bottom wing panel on top of spar. Drilled pilot holes and clecoed bottom wing panel .
wing on table after all drilled with pilot holes
blocks that level spar
blocks leveling spar
Zenith CH601 XLB Home
404
engine management
firewall
fuel tanks
ignition system
instrument panel
kit inventory
left wing
nose gear strut asse
right wing
wing updates
