Alans Web Site
Date:  7-5-2008
Number of Hours:  2.50
Manual Reference:  6w5-1
Brief Description:  right wing assembly
sorted right and left wing parts, to begin the right wing assembly. Marked and drilled spar for the wing end spar, marked and drilled end l angle. deburred and corrision proofed parts. When dry assemblied with clecoes and rivet with A5 rivets. Cut 6 - 60 inch long metal studs to lay out on table to support spar and wing assembly.
right wing clecoed
right wing clecoed
corrosion proffing panels and ribs.
