Brief Description: cut out end cover crank housing as per manual
Cut front cover housing out of corvair transmission bell housing, Rough cut to remove unwanted part of housing with power hack saw. Continued grinding cover with burr wheel to machine cover to corvair engine flight manual specs. Sanded with bench belt sander to further customize cover housing. Not finished after 1.5 hours. Need to trim excess material off of bottom were oil pan attaches to cover.
