Alans Web Site
Date:  8-24-2022
Number of Hours:  2.50
Brief Description:  test stand
After replacing front engine cover with high output oil pump and installing the oiil pan, I reinstalled carb and control cables. Installed battery mount and wiring, Installed exhaust pipes. I also installed in the exhaust longer baffles, to cut the noise. I have to install wiring for distributor and alternator needs a circuit breaker.
battery connections
battery connections
control panel
control panel
engine
engine
