Made a list of all parts I have on hand for engine. I find I forget that I have ordered parts for up and coming projects and than forget that I have ordered them. Check to see if there would be enough clearence between prop and ground when prop is installed on test stand. Plenty of room. Engine has oil leak in front on pan gasket. The gasket has being holding oil in pan above the gasket line and sitting for 1 year. Will have too redo gasket with new gasket and added gasket maker silicon high temp.
