Alans Web Site
Date: 3-5-2020
Number of Hours: 2.75
Brief Description: Installed the transponder and Icom
Installed the transponder, Icom and Navigation on instrument panel. Driledl holes for fuel select switch on center counsel. Plan on cutting holes for dual fuel level gauge and fuel pump pressure guage. I am going to mount the aileron trim gauge and elevator trim gauges on councel plus low oil pressure warning light, a carb heat on light and a park brake on lightt. If there is room the Icom headset jacks. Left side of panel includes holes for fuel mixture, throttle, carb heat and park brake cables.fuel ratio, tachmeter hrs gauge, turn coordinator, vertical speed Gyro, altimator.choke button, A/B engine run and ignition switch. List of gauges for right side include: Oil pressure,Oil temp, Carb temp, CHT temp, OST, temp, clock flap position,light dimmer switch, fuse panel indication, alternator charge, pitot heat light and switch. toggles swithes for landing lights strobe wing lights ,front head light.
instrument new arrangment
another view
center counsel
