Brief Description: installed coil wire tower/ taylor made coil wire
Installed the throw tower coil wire connector. Taylor made coil wire to connect to bottom of tower connector . Made a holder with plug wire clip to hold coil wire in place. I drilled and taped 8-32 an screws for tower. Final install I will seal throw tower with high temp silicon.
