Brief Description: finish the final touches on blast cover,for coils
The blast cover is finally coming together, I made the cover into 2 halves, it is now easy to remove and replace as per maintenance on filter, fuel pumps and ignition coils. The cover has a sceet flange mounted right in front of the Ellison fuel filter housing perfect for cooling the fuel going to the engine. The coils and fuel pumps and gascolator should all run nice and cool with the blast air coming from front inlet of crowl.In an earlier construction session back a couple of year I design the fuel pump plumbing to return fuel back to tank. I installed a small orfice in the return line fitting that will maintain 3 lbs of fuel pressure for the Ellison Carb . This method of fuel managment will bring the possiblilty of vapor lock down to nill.
