Cut slots in cover to accommodate the engine motor mount. Cut and clecoed l brackets to reinforce cover. Clecoed inlet to panel. need to cut hole next building session,Installed inlet to blow air directly onto Ellison fuel filter housing, down around ignition coils and then gascolator and out the bottom. Will have to cut panel into 2 sections for easy removal to service fuel filter.
