Alans Web Site
Date:  3-11-2018
Brief Description:  installed ignition wires on engine/ oil lines
Made and installed the engine ignition wire set. Bought a Accel 5041k universial wire set cut wires length to fit and crimped the distributor cap ends on with a MSD 35051 - Pro-Crimp Tool II. Firing order 1-4-5- 2-3-6. My engine is on the engine stand, and hope to mount on my trailer so I can give the engine a test run. I also installed hard lines to the cooler and oil filter housing. I will have to charge the battery its has been sitting for 6 months and the charge is low.
Ignition wires installed
more ignition wires
more ignition wires
battery
battery
