Mounted Aerocarb carburetor to engine. Then hooked up throttle and mixture control. Made nicely shaped heavy angle attachment braket to attach throttle to vertical angle support, positioned for nice feel. Everything slides and works OK. Throttle has a bit more friction than expected but slides through full open & closed travel well. Finished plumbing oil cooler and tapped oil cooler & attached adaptor under filter.
