Installed Smoke system tank and hose & electrical connections. Then - Fully designed & laid out, and then re-designed, and then added/changed-on-the-fly, a baggage compartment layout until it really came together and worked well. 3 flat panels, and a very complex C-panel with an access door to the smoke oil filler and multiple piano hinge pcs for the lower side wall attach. End result - a super light weight fully enclosed aluminum powder coated panel baggage compartment. Smoke System and ELT are completely surrounded and the elevator control rod is completely protected. Throw baggage in and no worries about elevator rod interference. The big rear panel and the C-panel are quickly removable with sheet metal screws. Came out nice. Also attached Com antenna and cable.
