Spent a lot of time fabricating battery case, came out nice. Side door for easy replacement will require 8 bolts to take out. Don't plan on removing often and don't want hinge pins. Mounted Amp Shunt, Ground Buss Bar, Regulator and Main Relay to firewall. Worked on huge 4ga wire connections from battery to neg & positive connections. Very solid & nice heavy ring terminals. Hooked up power and spent over an hour troubleshooting mistake on switch connections. The Lighted Rocker switches didn't have connection diagrams for the 3 plugs on each one and they were backwards. Finally figured them out, and everything Powers Up and Works BEAUTIFUL. This is absolutely the sweetest Sonex Glass Panel out there. And probably the most expensive.
