Fitted, trimmed, zinc'd and riveted wink walk / left root doubler, and right root doubler. Worked on Brake cable routing, brake handle & angle & attach parts making. Also - Fixed play in control stick weld assembly. Added small angle attach points to inside points of control so the rotating bolt has supporton each side of the bushing & weld plates. Super smooth & free, with Zero play now. Much better.
