Brief Description: Fwd Fuselage details, motor mount & rear gear
Finished riveting forward fuselage stiffeners & front wing spar tunnel pcs. Mounted welded motor mount assembly, hardest thing yet in entire project - lower bolts impossible to mount without mods. Finally came out good & solid. Removed rudder to put in forgotten elevator control stick before too much gets in way. Broke 8 bits machining rear tailwheel titanium leg, long struggle connecting it. Goal is to get fuselage on gear on floor next.
