Assembled pushrod verticals, and spent most of the time wrestling with grasping the rear tail wheel mount, vertical stab channel, spacer, angle assembly at the back tip. Finally got it all fitted very nicely and drilled it all out. Came together very solid in the end after fully getting the order and configuration of parts back there.
