Finally moved into Barn/Workshop! I'm not going to record the 200+ hours of actual construction of the barn. It took 3 months to build. The plane will probably take a year. The attic holds all the skins, and all the parts/shelves/main-bench/tools are all moved in & set up. The inside picture below was during layout of the 12' main assembly bench. The plane will fit inside fully assembled, when the bench is taken out.
