Brief Description: Finished Riveting Inboard Rib of RHS OB LE
There were a few rivets left on the RHS OB LE inboard rib to rivet, so I finished them off. Initially I tried to squeeze them, but I ended up bucking them instead. The curved surface made it a lot harder to get a good set on the rivet and I had to drill out a couple. The forward most rivet on the upper surface wouldn't set in the dimple properly and no matter what I did I couldn't get the holes in the parts to line up properly. I ended up opening up the hole to #30 and installing a NAS1097 oops rivet and that did the trick.
Space in the garage is getting tighter, so I moved the big assemblies into the dining room
