I trimmed the confidence layup today, using the fein multimaster. I really can't imagine trying to get out to the shop for the knife trim stage every time, although I did try knife trimming on this layup when I got home the night I did it, and while it did seem easy, this is way better. You just score along the line you're going to cut, and then work the saw back and forth in that grove until it falls through.
The mark on top is the centerline. The epoxy made it bleed.
Closer image. I need to cut the glass a bit more oversized if I'm using the masking tape.
The multimaster made quick work of the trim process.
