The RV-10 Dream
Date:  4-15-2014
Number of Hours:  4.00
Brief Description:  Putting the Prop on :-)
Last night Dad and I went to the Airport to fit the propellor to the plane.
Up until then, I had not noticed that the tips of the prop were also white. This sets the aircraft paint scheme that I am after off quite well.
For those who have done this before it is quite an excercise. I needed to remove the "plug" from the mounting hub before fitting the prop.
After a quick call to Mick (i.e. Haynes), I remoived the plug, cleaned the area and fit the prop. 2 turns on each nut at a time for about 15 minutes..... What a pain.
Taped two spanners together and calculated out the required torque to be set on the torque wrench.
Final figure was:
This calculation is to take into account the additional length of the extension (i.e. the spanner) of 8.25".
(60 x 1.25)/(1.25+0.6875) = 42 ft Lbs set at the torque wrench.
Now all I need todo is complete the lockwiring of the nuts and it is complete.
I did have issues mounting the fairing,so I am going todo soime investigation on how people have gone with this while the propellor is mounted. Anyhow expect wings and wiring to nbe completed within next two weeks.
Plug requiring removal
Looks pretty with the prop on.
