The RV-10 Dream
Date:  10-13-2013
Number of Hours:  12.00
Brief Description:  Painting and assembly of cowl baffle
Over the weekend, Dad and I worked on the baffling of the engine. I decided to try the default baffling material and process and then later, if required, I will go the plenum route.
I was struck down tonight however, when while resetting the altimeter to compare to the AFS stuff the knob failed to operate. I have emailed Winter Germany to see what I am to do about it, however I have had no reply.
This altimeter appears doomed as it has gone through the foillowing to get to here.
1. Purchased from a reseller, however, provided with incorrect pressure readings: Inches Mg rather than Millibars
2. Returned and an alternate provided with incorrect hand markers
3. Returned and supplied with a case that had obviously been installed in an aircraft previously and the mounting screws were damaged
4. Finally returned and now the unit does not work at all.
I think that this is just a dodgy unit and needs a complete replacement.
That being said, Archim Winter has been quite good to work with. I am not in the air and he has helped to try and rectify any issues as they occured. I am sure it is just one of those things in aviation where all of the swiss cheese holes lined up....
Winter Altimeter not working
Baffles painted and baffled
Very nice.
Very nice.
