The RV-10 Dream
Date:  10-27-2012
Number of Hours:  4.00
Brief Description:  Correcting Front Wheel and Wheel assembly
I created a plug that would fit into the "old" valve step hole, used a tap and die and screwed the plug into the hole and secured with epoxy. I ground flat the two sides of the plug.
As can be seen in inage 2, I have also created a support for the step and it is clearly at tire height. There will be no issues associated with clearance now.
Machined Plug with Tap
Valve stem fully clear
Plug final fit
Plug final fit
